Go Back   CustomTacos.com Forum > 4x4 and PreRunner Discussion > 4x4/PreRunner Wheels and Tires
Register FAQ Calendar Search Today's Posts Mark Forums Read Advertise
Old 11-02-2009, 03:48 PM   #1
AlienX
AlienX's Avatar
Tacoma: 2010 tacoma SR5 4x4 double cab.
Default Stock rims
I have a 2010 tacoma SR5 4x4, I was wondering if anyone has put on 265/75/16 BF Goodwrench A/T and had any luck with them not rubbing too bad of bottoming out?
AlienX is offline   Reply With Quote
Old 11-03-2009, 02:31 PM   #2
Discount Tire Direct
Supporting Vendor
Tacoma: all
Default Re: Stock rims
I show it should fit without any problems. There will be a small effect on your speedometer. Here's a link to estimate how much.
Tire Size Calculator
Discount Tire Direct is offline   Reply With Quote
Old 11-04-2009, 03:19 PM   #3
Bugvomitz
Bugvomitz's Avatar
Tacoma: 2004 DOUBLE CAB,V-6 3.4
i have a question, i have a 2004 double cab 2wd. i just put a 2" leveling kit up front and 3" blocks out back, both products by ready lift. im supposed to be able to put on 32's now, that true? im actually more interested in gaining some width, ho wide can i go? whats your take on spacers?
thx
Bugvomitz is offline   Reply With Quote
Old 11-04-2009, 03:32 PM   #4
AlienX
AlienX's Avatar
thanks for the heads up, I saving up my $, then will be heading to my local Discount for these tires soon.
Old 11-05-2009, 12:11 PM   #5
Supporting Vendor
Tacoma: all
thx
Do you plan on running the factory wheels or aftermarket wheels? If the wheel dimensions are correct, you'll be able to clear 32" tall tires with no problems. The max recommended width will be determinded on the wheel dimensions.
As far as spacers go, we do not recommend them for a variety of reasons.
Old 11-09-2009, 03:41 PM   #6
Bugvomitz
Bugvomitz's Avatar
*im still on stock wheels
Old 11-10-2009, 12:30 PM   #7
Supporting Vendor
Tacoma: all
Size 265/75-16 is the max recommended tire size for your factory 16x7 wheels. I recommend doing a test fit if possible to check for inside clearance as you factory wheels have a high +30mm offset which may tuck the tires in to far causing tire rub on your suspension components.
Old 11-10-2009, 03:13 PM   #8
Bugvomitz
Bugvomitz's Avatar
*sweet, thank for your help!
Old 11-17-2009, 10:18 PM   #9
trailhoor
Tacoma: 2008, Access Cab, TRD Off-road
Hah, funny you should ask- that was one of the first things I bought for my truck since those piece of **** stock tires (Rugged Trails) wore out on less than 10k. I bought the exact tire (if you mean Goodrich) on stock 16" alloy wheels.
They fit for the most part, except when you turn and compress the suspension. It bugged me enough to look at raising my truck, which led to a suspension upgrade, 2" lift up front 1" in the rear (not to mention a whole bunch of other mods) and my tires do not rub anymore
Bottom line, the 265/75s look way better on the stock truck, they rub a little. I'd get them if I were you...
Locker mod, System, Icon c/os, Icon UCAs, Icon remote resis, Alcan leafs, Chambers Teflon wheels, BFG A/T 265/75, TRD s/c, APR X-1
trailhoor is offline   Reply With Quote
Old 11-18-2009, 08:05 AM   #10
AlienX
AlienX's Avatar
Thanks, I am looking to put that same lift on my truck, any suggestions?, i am looking at a Tuff Country right now
vB code is On
Stock TRD alloy rims Matt450 Wanted 2 09-29-2009 11:45 PM
F/S 01-04 Stock rims and tires OutKaStaCo Wheels and Tires 4 09-07-2009 06:31 PM
4 stock 02 rims Trtle Wheels and Tires 28 01-23-2007 09:35 AM
06 stock silverado rims and new tires!!!! Trtle Wheels and Tires 6 09-16-2006 02:07 AM
Biggest Tires On Stock Rims? atticus 4x4/PreRunner Wheels and Tires 2 01-27-2005 08:28 PM
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
