Go Back   CustomTacos.com Forum > On The Go > At The Track
Register FAQ Calendar Search Today's Posts Mark Forums Read Advertise
Old 11-04-2009, 08:05 PM   #51
1st_TACO
1st_TACO's Avatar
Tacoma: 04 Taco 2.4L 5-spd turbo, 86 4wd BEATER DD, Aprilia SXV 4.5
Default Re: Went To The 1/4 Mile
Originally Posted by taco on steiroids View Post
hey mckeever, what size injectors are you looking to install next time around? perhaps that was answered earlier in the thread but i noticed your profile says pink tops and a 255 fuel pump. is that still current?
i have pink tops plus an additional 650 injector with a 190 fuel pump, i have needs to deliver more fuel at a higher accuracy as well and not sure if you can go too big assuming ur still running a stock fuel rail or close enough
stock rail will go out to 400+(rwhp) depending on setup
im still on the stock rail, regulator, and lines
http://www.youtube.com/user/SXVtommy
357HP/323TQ @ 15PSI
1st_TACO is offline   Reply With Quote
Old 11-05-2009, 03:01 AM   #52
McKeever
McKeever's Avatar
Tacoma: 98 Turbo Taco 2WD Std. Cab 5 spd & 79 4WD Toy Pickup
AEM is hard to work with compared to others, but I know some people in town that are good with the AEM, one reason why I went with it.
I plan on installing some 440's that I got off of a supra along time ago. 440's will keep me below 400hp which will work good with the stock fuel rail (like 1st_TACO said), also the 440's should fit in the fuel rail with no problems. That's the plan anyway.
13.165 @ 104.84 1/4mi on 9psi
McKeever is offline   Reply With Quote
Old 11-07-2009, 06:31 PM   #53
stoner
stoner's Avatar
Tacoma: 2000 tacoma inline 6, 5 speed cabplus.
Haltech baby easy to do trust me i did it
stoner is offline   Reply With Quote
Old 11-07-2009, 11:01 PM   #54
McKeever
McKeever's Avatar
Well shoot, if you can do it anyone can!
We should have a meet: AEM vs. Haltech vs. Megasquirt
Old 11-08-2009, 03:36 PM   #55
Speed Freek
Supporting Vendor
Speed Freek's Avatar
Tacoma: 98 Taco extra cab 2RZ GT30R Turbo Intercooled
I will represent Haltech 2.4 class....
As far as installation goes any standalone will be a decent amount of work, you need to wire up your sensors and injectors, fuel pump, etc....plus you need to know polarity of some of these sensors/drivers and if you tap into the stock harness you need schematics and know how to properly read them.
Then after that you need to figure out why it wont start, then figure that out, then you need to get it to run, the you need to get it to drive, then you start tuning and figuring out how to tune it.
A standalone is not for most people, since it requires a great deal of knowledge to get going. Not to mention the numerous hours of learning curve before you even know what your doing, or at least think you know what you are doing.
It gets comjplicated when dealing with all the different modifiers based on load temp and other conditions, and one thing always affects others so it can get frustrating.
However I loove my Haltech!! FTW!!!
BOOST BRIGADE (19psi)
Traction bars (2wd), Strut rods (Heims), and Forward facing intakes (2/3RZ) available for 95.5-2004 Tacomas
www.speed-freek.com Fabrication and repair
Former Toyota/Lexus Tech.
Speed Freek is offline   Reply With Quote
Old 11-08-2009, 03:58 PM   #56
siggie30
siggie30's Avatar
Tacoma: 97 taco reg cab, 07 taco reg cab
Originally Posted by MatosTaco View Post
If I were you I would try a wider tire. I have seen Tacomas comfortably riding on 245 width tires and that gives you a wider footprint. My stock tires are 215.Of course, redoing your suspension will have great results too. By the way, how much was the Truetrac?
x2, I have 245 and they hook okay for a street tire. I personally would not recommend airing down a street radial.
siggie30 is offline   Reply With Quote
Old 11-17-2009, 03:49 PM   #57
voodootrip
4-Linked Mod
voodootrip's Avatar
Tacoma: 2001 BSP S-Runner... yummy
275's and a locker and I still can't hook-up ...
yes it's a truck... yes it's fast
Tacoberwest2009 brought to you by:
SittinSic ParadiseRacing Engage offroad Fatty's Bar and Deli The Truck Shop
voodootrip is offline   Reply With Quote
Old 11-17-2009, 06:50 PM   #58
TrboTaco
Veteran
TrboTaco's Avatar
Tacoma: 97 taco "The Burrito", Daily Driven 01 SR BSP S/C'd & NOS'd (11 sec Club) "Project Qiktaco"
McKeever,
In 2001:
-no load leaf,
-Nitto Drag Radial 555R's with around 20psi
-an open diff
-launching somewhere around 4500rpm/rev limiter.
-cutting consistent 2.0 60'
-high 13's even missing fourth on 10psi.
With what you have done, you should be right there if not faster.
If you can't get traction, air up the tires and find the sweet spot.
Voodoo,
Spin the tires over on your way up to the line next time to clean any sand, water or debris off your tires. It has helped me in the past. Now I just run a set of MT DR's and cut 1.6x 60's. Link in sig of my buddy who owned the truck before and is still a driver from time to time.
Either of you have a traction bar or some sort? Helped us a lot!
2001 S-Runner BSP | Best E.T. = 11.701 | Best MPH = 115
Best 60' = 1.59 (vs. GTR) |
DynoDynamics Dyno = 387rwhp & 420rwtq | SR vs GTR
TrboTaco is offline   Reply With Quote
Old 11-17-2009, 07:39 PM   #59
McKeever
McKeever's Avatar
Well I'v gone 13.1 @ 104 with a 1.9 60ft
That's with chassis tech leaf springs, 2" block, truetrac, 26x11.5 MT ET streets.
I was running low 13's most of the time last year, just did not work out that way this year.
Old 11-17-2009, 09:57 PM   #60
voodootrip
4-Linked Mod
voodootrip's Avatar
Mine was on street tires. I took off my traction bar to do the 4-link. Not getting to much (at least as much as I thought I would get) wheel hop. My best 60 foot was that first run of the night. The glue was fresh and I was literally the first vehicle on the track that night. After that ambient air intake temps. and no tune for the area made the runs worse and worse.
vB code is On
9/26/07 to 9/30/07 - Nellis AFB, Multiple Events - Nevada MNewman Pacific Region 15 09-14-2007 10:49 PM
Car Show, Drifting, Auto-X, and more in VEGAS!!! MNewman Pacific Region 41 09-12-2007 10:32 AM
1/8 mile to 1/4 mile calculator red-x Performance 3 01-23-2007 09:11 PM
XR in the 1/8th mile. Red X X-Runner Talk 13 06-15-2005 09:50 AM
1/4 mile times... dropthattaco At The Track 72 11-22-2003 10:32 PM
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
