Go Back   CustomTacos.com Forum > 2wd Discussion > S-Runner Talk
Register FAQ Calendar Search Today's Posts Mark Forums Read Advertise
Old 11-05-2009, 09:28 AM   #21
Hug it out bitch
Tacoma: 02 X-Cab SR5-lug
Default Re: S-Runner TrueTrac Install Write up
Originally Posted by lobody94 View Post
Great write up!
When we did the LSD in the DCSR we were able to loosen the backing plates on the drums and pull the axles out far enough to pull the third member. It saved us from having to deal with the brakes.
Wouldn't that ruin the seals from having it hang like that?
In the corners, the stock battery hold down is no match for my driving style..
Chris D. is offline   Reply With Quote
Old 11-05-2009, 12:29 PM   #22
kevinthefawker
kevinthefawker's Avatar
Tacoma: 98 tacoma extra cab
nope i did that a few time swhen i regeared my diff then took it back out to reinstall my stock 3rd.
kevinthefawker is offline   Reply With Quote
Old 11-05-2009, 01:29 PM   #23
SRunner-CR
Tacoma: 2003 S-Runner
Exactly.....that's what the guy did when he replaced mine. Just make sure you pull it out straight and I don't think you'll have any issues. If you're worried get a second set of helping hands. Actually from what I remember........he pulled out one side a bit, had me hold it and pulled out the other side then got the third out somehow and pushed back in the axles while he worked on the third. Don't quote me on this, but I'm pretty sure he did something like that, because I remember asking him about the brake line, yada, yada, yada and he said this would make things quicker as long as you're careful.
BTW: Great write up!!!!!!!!!
Work Hard.
Play Harder!!!!
SRunner-CR is offline   Reply With Quote
Old 11-05-2009, 01:31 PM   #24
Hug it out bitch
Is there any chance of the wheel bearings coming off or sliding on the axel when doing this?
Old 11-05-2009, 01:57 PM   #25
heloboby7
heloboby7's Avatar
Tacoma: 05 RR Xrunner
Not at all.
2005 Tacoma X-Runner RR- Precision 6152S turbo -SOLD
2001 Tacoma S-Runner BSP- TRD Gen 2 charger, much more to come.
heloboby7 is offline   Reply With Quote
Old 11-05-2009, 01:58 PM   #26
Hug it out bitch
if you undo the 4 backing bolts and the axel can just slide out without having to remove the backing plate, whats keeping the axel from sliding out when tightened up?
thats what I'm confused about because I really don't want to dick with the brake lines..
Old 11-05-2009, 02:09 PM   #27
TACO626
Grand Tacoholic
TACO626's Avatar
Tacoma: 2004 S-Runner
I installed my TRD LSD without any help, not that hard. You can also pull the axles out far enough to remove the 3rd..... pull em out straight and sit them on a few blocks of wood. This will prevent any binding and contact with seals and bearings.
GL
Blown
TACO626 is offline   Reply With Quote
Old 11-05-2009, 07:10 PM   #28
Mambeau / Moderator
Tangential discussion on Eaton/TRD versus TrueTrac LSD's has been split off into its own thread:
http://www.customtacos.com/forum/sho...d.php?t=139323
Enola Gaia is offline   Reply With Quote
vB code is On
Eaton 7.5" Rear TrueTrac Install Stock Taco Performance 46 09-03-2009 11:51 PM
Roof Rack Install (shell) ToyotaDrifter Exterior/Body 2 02-10-2009 09:29 AM
Avic D3 Install, two amps, 8" sub, and 6.5 components tons of pics dgilling Interior/Audio/Electronics 15 03-30-2008 07:44 PM
ARCHIVE: 2000 Bench to Bucket Seat Install Enola Gaia Interior/Audio/Electronics 0 02-10-2008 11:10 AM
4wd brothers va burnt taco Off Road 19 01-03-2008 10:57 AM
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
